gijoecam
Mar 05, 2015Explorer
randallb wrote:
The hitch manufacturer will let you know if their sway control can remain installed when backing up. If they say no backing up they mean it. The hitches that allow backing are usually the ones with the sway control built in to or on to the end of the bars. The hitches that you should not back up usually have the separate sway (friction) controller that mounts between the hitch head and the trailer tongue. If you do not disconnect the sway control you will be replacing the weak link when it bends. Hopefully the weak link is the sway controller not the hitch head or the tongue.
Randy
Please explain how a standard friction away control has any idea which way the rig is travelling and how the direction of travel changes the function of the device in such a way that it (the direction of travel) causes the failure? How is moving the rig backwards going to cause it to fail when moving forward doesn't?
44,068 PostsLatest Activity: Jun 01, 2026
