I appreciate all the feeback!
So as originally thought, it sounds like I should spring for a new WDH.
From the reviews I looked at I like the Equalizer. It's also a lower profile and my trailer is fairly low (the Reece dual cam does hang down a bit. Had one a few trailers ago)
Should I go with the 1200#?? 1400# would allow more weight options but would it give up ride quality when running less load?
Also according to the Equalizer website you only add behind the axle cargo weight? (I've always used all passengers and truck cargo)
Thanks for putting up with all my questions...:S
