rabboys's avatar
rabboys
Sway problem need help
I have a 26H terry 26' foot travel trailer and installed a 4x8' platform on the back of the trailer. Designed by a engineer for my harley. Total added weight is 1100lbs. At 55mph the trailer sways. According to the engineer there should be sufficient tongue weight which I don't think so. I am using a reese equilization hitch with one friction sway bar. I am looking at several options but naturally don't want to go over board but want to be safe if I can even make it to work safely. I though of using two friction sway bars, to dual cam sway system to pro pride or Hensley no sway hitch. Really I don't know if any of the above will work. Without the harley no problem. The extension is about 300lbs and the harley is 750lbs. I would appreciate any advice including to scrape the plan of hauling the harley. Thanks Tom
