Travlingman wrote:
When I was trying to decide on 3.55's or 4.10's a guy on the Ford forum figured out the different RPM's for the ratios and RPM's. Here it is.
4.10 DRW
4th gear 55 = 2764; 60 = 3015
5th gear 55 = 2061; 60 = 2248; 65 = 2435; 70 = 2622
6th gear 55 = 1624; 60 = 1772; 65 = 1919; 70 = 2067
Sweet spot for climbing: 64 - 75
3.55 DRW
4th gear 55 = 2393; 60 = 2610; 65 = 2828
5th gear 55 = 1784; 60 = 1946; 65 = 2108; 70 = 2271; 75 = 2433
6th gear 55 = 1406; 60 = 1534; 65 = 1662; 70 = 1790
Sweet spot for climbing: 55 - 64; > 74
He considered the sweet spot for climbing the big hills to be in the 2400 - 2800 RPM range.
I went with 4.10's and his figures appear right to me from my driving/towing experience.
2400-2800 rpm may be the sweet spot for towing hills. The thing is you need to factor in your weight and the slope of the grade to be able to know how fast the engine can tow your trailer up the hill.
Just guessing your truck and trailer combined might weigh in at about 25000 lbs.
If you are wanting to tow your trailer up 6% grades you can easily calculate that the rear wheel power required to overcome the grade:
.06 x 5280 ft in a mile = 317 feet per mile.
At 65 mph your going to travel that mile in 55 seconds.
So you need to be able to lift 25000 lbs 317 feet in 55 seconds.
1 Hp is the power required to lift 550 lbs 1 ft in 1 second.
Therefore: (317 x 25000 รท 55)/550 = 262 HP
Additionally you can expect that it will take roughly 100 rear wheel hp to overcome wind and rolling resistance at 65 mph.
The rear wheel hp required to tow your trailer up a 6% grade at 65 mph is 362 hp.
Power is lost to heat in the rear end and transmission as and there is power required to run things like your cooking fan a/c and alternator. To get 362 hp to the rear wheels your engine would be required to make much more than 362 hp.
It's kind of a guess but it you assume an efficiency of 75% your not going to be too far off. This means that to put 362 hp to the rear wheels your engine would need to produce 482 HP. That's not going to happen. At 2400 rpm The 2017 Powerstroke will make about 395 HP.
Your going to be pulling 6% grades at speeds closer to 55 mph. So according to what your friend calculated you will be in 4th gear at 2800 rpm which is great. The 3.55 gear ratio would also be in the zone at 2400 rpm.
And on a little steeper grade the 4.10 would shine but on a little less grade the 3.55 would shine. As the grade approaches 8% the 3.55 equipped truck will our perform the 4.10 again. Fuel economy will go to 3.55 gears.
