valhalla360
Mar 29, 2018Navigator
Possibly not going to work. The bi issue would be tongue/pin weight.
Assuming the swivel wheel is roughly 50% on the wheels and 50% on the rear of the frame (let's call it the rear bumper but actually attached to frame)...figure around 1500lb total or about 750lb on the rear bumper.
MH: It's not an issue as it's directly attached to the tow vehicle. As long as it can support 750lb, you good.
5th wheel, you start at 20-25% pin weight. Let's assume 2500lb pin weight. The wheels are approximately 2/3 of the way from the pin to the rear bumper. When you run the math, that means, for every 2lb you put on the rear bumper, you take around 1 lb off the pin weight...so about 375lb...that leaves you 2125 pin weight. So if you were only at 20%, that still leaves you with 17% pin weight...a little light but it will probably be fine. If you started at 25% or it was a heavier trailer, even less of an issue.
A TT on the other hand has wheels approximately 55-60% from the ball to the rear bumper and around 10-12% tongue weight. At 60% every 2lb on the rear bumper takes 1.67lb off the tongue. So taking your measurements, 4400lb and assume 12%, that means you start at around 440lb tongue weight. Let's assume 60% back and 750lb at the rear bumper...that's going to take around 500lb off the ball...oops, that's a negative 60lb tongue weight.
There are some things you can do to compensate but you are so far off, it may be too extreme to solve.
- Add extensions to the swivel wheel attachments. The longer you make them, the more of the weight rides on the wheels rather than the rear bumper. You might be able to get as much as a 33/67 split but make sure you don't overload the swivel wheels as they may have been spec'd assuming a 50/50 weight split.
- Move cargo forward in the TT. The more weight you can move to the front, the more the tongue weight increases...the challenge is moving enough to get the tongue weight up at least to 10%...less than that and most TT dont' tow well.
So it's possible but really probably not a good idea.
You aren't talking about a really heavy item, so probably simpler to get a hitch for the car and have the wife tow the golf cart separately if it's only occasionally and not too far.
