Huntindog
Feb 21, 2014Explorer
Some here apparently do not understand the function of the low beam cutoff. It is to keep one from blinding oncoming traffic.
It is much more defined in a high performance headlamp, as it needs to be.... Since it is a lot brighter, the blinding risk is more of a problem.
One really doesn't need the cutoff area illuminated with low beams anyways. Anything that needs to be seen with in a low beam situation can be. Unless these moose are floating off of the ground!!:B If you need more light, then you should be in a high beam situation.
44,068 PostsLatest Activity: Jun 01, 2026
