Need-A-Vacation
Aug 29, 2015Explorer
Stlsailorrv,
As I mentioned in your thread on JOF, I would go for the HD Tow Package. The extra gearing it has, higher payload, and the factory brake controller are worth it! As mentioned over there also, you may end up upgrading the trailer a little down the road and the Tahoe with the HD tow pkg may still fit work.
What are the family needs as far as seating? The only downside to a Tahoe (not sure about one with the HD pkg) is you may run out of payload before reaching the max tow rating. Total weight of all passengers, cargo, animals (besides kids!), wd hitch, and the trailer tw all add up toward the tow vehicles available payload. Probably be fine with the current trailer, but if you step up to a larger trailer down the road you may need more payload.
What about a crew/extended cab truck. Maybe that would have more payload???
Good luck!
Good luck!
44,066 PostsLatest Activity: Jul 25, 2018
