stlsailorrv
Aug 29, 2015Explorer
jerem0621 wrote:
From the limited research I have done on GM's I believe they all have a tow/haul mode during the years you are looking for.
You 'can' add the HD equipment yourself. You can add aftermarket transmission/engine oil coolers...HD radiator (if it's actually different)...and change the axle ratios to 3.42 (if changing, I would do 3.73 or 4.10..but that's just me). You can also add a great aftermarket brake controller and a stronger non POS receiver and make it a towing machine.
The Tahoe is a great compromise vehicle...they handle good, have good daily driver manners, are comfortable to drive.
Good luck in your search!
Thanks!
Jeremiah
What do you mean tow/haul mode?
The oil coolers actually aren't part of the package I was surprised to find. They come standard, and I wouldn't want to tow anything without them. But since they aren't part of the HD package, that's what raised the question in my mind if I really needed the HD package or not.
Why the higher axle ratios? What do you see as the pros and cons? I don't know much about axle ratios.
44,066 PostsLatest Activity: Jul 25, 2018
