tbolt2000's avatar
tbolt2000
Tahoe Towing Tow Mode or Range Selection Mode?
2012 Tahoe 6 speed which is best for towing..
Gear shift in "Tow/Haul Mode" or set the " Range Selection Mode" to maybe 4th or 5 gear?
Range Selection Mode is a feature where you set the mode to Manual and select the highest gear it will automatic shift to and not go past that gear.
e.g. set it for 4th gear and the transmission never goes into 5 or 6 gear.
The manual states:
The vehicle may have a Range Selection Mode. The Range Selection Mode helps control the vehicle's transmission and vehicle speed while driving down hill or towing a trailer by letting you select a desired range of gears.
To use this feature, do the following:
1. Move the shift lever to M(Manual Mode).
2. Press the plus/minus buttons, located on the steering column shift lever, to select the desired range of gears for the current driving conditions. When M(Manual Mode) is selected a number displays next to the M, indicating the current gear. This number is the highest gear that can be used. However, the vehicle can automatically shift to lower gears as it adjusts to driving conditions. This means that all gears below that number are available. When 5(Fifth) is selected, 1(First) through 5(Fifth) gears are automatically shifted by the vehicle, but 6(Sixth) cannot be used until the plus/minus button located on the steering column lever is used to change to the gear.
Grade Braking is not available when Range Selection Mode is active.
While using Range Selection Mode, Cruise Control and the Tow/Haul Mode can be used.
Wonder if Tow/Haul Mode with the Range Selection Mode set to 4th gear would be best?
  • mguay wrote:
    Push the T/H button and let the trans decide which gear it wants to be in.
    X2. If you find for some reason the transmission is "hunting" then go to manual and lock out the higher gear but stay in Tow/Haul mode
  • Push the T/H button and let the trans decide which gear it wants to be in.
