Kayteg1
Aug 26, 2016Explorer II
lonegunman wrote:Kayteg1 wrote:
For those running propane generator for heat- research the subject as propane tanks need heat for changing from liquid to vapor stage and at certain temperature it ain't going to happen.
It seems to happen just fine to zero degrees. I'll be careful if I camp on the Hudson Bay in winter.
Did you run generator at this temperature.
Propane vaporize at -44F, but as I stated you need lot of heat to do it, so when small water heater will work fine below 0, high flow will drop the cylinder temperature down to -44F and no kudos.
