alenk wrote:
Regardless of what you are using as a tow vehicle a single axle trailer will bounce when you are towing it. I've had single and tandems, and the single will scatter contents around inside. A tandem axle will be much smoother on the contents. JMHO.
Al
I don't agree with this. I suppose a single axle trailer is lighter but that doesn't mean they all bounce. The ONLY reason a manufacturer goes to a double axle is the weight of the trailer. Bigger heavier trailers need two axles. Some of these large trailers also bounce if not properly designed and set up for towing.
