gordinho80
Sep 04, 2020Explorer
Well, after digging a little deeper, looks like everything is actually in working order. Battery terminals were loose. So I tightened those down... then realized the breaker inline with the 12v wire was tripped. Reset that. After being all connected properly and hooked up to shore power for a day, battery tested 13.8v and the panel worked. Don't know if the battery will hold a charge yet... will be testing that out in coming weeks. Going to hook up a power inverter to it so I can run my residential fridge while in tow. Will disconnect shore power when I get the inverter set up and see how long the battery runs the inverter for. If we can't get a good run, at least a couple of hours, then I'll look into upgrading the battery. I'm hoping to get at least 5-6 hours of inverter/fridge run time while in tow. Maybe run larger gauge wire with some Anderson plugs to send more juice to the trailer while hooked up to tow rig.
44,066 PostsLatest Activity: Apr 15, 2026
