Yngrver
Jul 19, 2014Explorer
Tank Problems
The dreaded "tank problem"s.... I am having trouble with both my gray tank and my black tank. 1) My gray tank is continuously clogged. I have to take a plunger to it about once a month to empty...
gbopp wrote:
Try The Geo Method in your tanks.
Did you try filling the tanks with water and leaving it sit for several days? Maybe it will soften the 'stuff' inside the tank.
Another possibility is, put some water in the black tank and dump a couple bags of ice down the toilet. Then take the RV for a drive and allow the ice to slosh around and loosen everything stuck to the walls.
You are leaving the black tank valve closed until the tank is about 3/4 full before dumping?
