sean4fsu's avatar
sean4fsu
Tankless Water Heater Compatibility?
Tankless electric water heaters are so expensive, and I was wondering if anyone knew if this model would work in our 2007 Terry Travel Trailer Camper? I would like to use it for our shower.
https://www.ebay.com/itm/NEW-Rheem-Electric-Tankless-Water-Heater-6kW-RETEX-06-Self-Modulating-SEALED/143340591004?epid=20021167549&hash=item215fc3d79c:g:jcsAAOSwxuRdGyAQ
https://www.rheem.com/product/performance-tankless-electric-3-6kw-electric-water-heater-with-5-year-limited-warranty-retex-06/
And if it does fit, how would we convert it to be used in our camper?
  • Try looking online at RV tankless water heaters I have been wanting one of the Gerard ones they have good ratings and are less than $500.
    https://www.amazon.com/Girard-2GWHAM-Demand-Tankless-Heater/dp/B019BWN8E2
  • Keep in mind venting requirements for propane units. They can be dangerous if not installed properly.
  • Can you build a lean-to? Put it right outside where the factory WH is, and install the heater you plan to put in your house...
    I was thinking something similar.
