hohenwald48
Jan 12, 2017Explorer
RvNewbieFl wrote:
... Spending that much time there with only navy showers, ...
What makes you think navy showers are necessary? The only time we are restricted to navy showers is when we have to ration water or gray tank capacity. At a full hook up site normal showers are, well, the norm. With the water heater on electric and gas the recovery time is right quick and we never have had a problem with a shortage of hot water. You are likely implementing an expensive solution for a problem that doesn't exist.
It sounds like you have already made up your mind but I suspect that if you would give it a try you'd find a better use for $1,000. You might want to consider how fast you might run thru propane with an endless supply of hot water. I have no idea what their propane consumption rate might be.
