nevadanick's avatar
nevadanick
TC ???
I really want an Arctic Fox 990. I have a Ram 2500 and if i went with Toyo 18in i can get to 8000 on axles. Weighed the truck today and full fuel, me and wife and **** normally in truck and was 3300 on rear, 5300 frt. I assume with the camper that the tailgate and bumper would be removed and i could move the spare up front. I still need some room for toungue weight. I am not against a dually but i have only had this truck a year and a half. Trying to make sense of it all.
  • nevadanick wrote:
    The guy has more stuff in it than my house. He said he has weights for lifting. Researching Dually already as my boat and trailer are approx 7500 lbs and i also have an enclosed trailer that varies from 4-8 k. By the time i add tounge weights i will need it.
    Lol yeah I forgot about that he was carrying his workout weights. He is living in it fulltime too.
  • The guy has more stuff in it than my house. He said he has weights for lifting. Researching Dually already as my boat and trailer are approx 7500 lbs and i also have an enclosed trailer that varies from 4-8 k. By the time i add tounge weights i will need it.
  • You'll need a rear suspension upgrade along with tires/wheels. If you aren't against a DRW, it would probably be better in the long run to go that route. You'll lose money on the tire/wheel swap. Even if the 18 tires are rated at 4000, the wheels probably aren't.
  • Bedlam wrote:
    You're looking at 4500+ lbs for an AF990. I would suggest 19.5" wheels instead of 18's if you want to keep the truck - Otherwise, start looking for a DRW.
    Agree with Bedlam 100 percent.
  • You're looking at 4500+ lbs for an AF990. I would suggest 19.5" wheels instead of 18's if you want to keep the truck - Otherwise, start looking for a DRW.
