Front install:
Fishing tool.
fished
here
This, is actually the right side mount, the fishing tool is on the left side of my truck…
Shelving brace for closet, now tool to push the frame-mounted wiring away from the bolt hole so bolt no pinch it.
just shove it in, tank is plastic…
bolts right in, this is left side
this is right side
low profile, does not really hang low when not in use. Nerf bars are lower. Does not hang so low when inserts are in either.
other side
other side
with insert, left.
1.5 inch insert tubes.
Very easy install. I suggest doing the non fishing side first.
Rear is next.
I will post this as a new thread for install references….
