Bob__B's avatar
Bob__B
TC Battery Charging Solar, Shore Power, Vehicle?
I recently retired and purchase a new..er TC.
I would like to get it set up for maximum flexibility for charging the TC batteries.
I have been studying solar, and understand how it works independently. I think I also understand what I need to do to my vehicle to optimize the charge current I can get from it. I don't really understand how solar would play together with with the vehicle charging and also shore power.
I know when the camper is not plugged in the on board charger automatically disconnects, but don't know what happens if I have solar and have the shore power plugged in, or if I have the vehicle running and it is supplying power at the same time solar is.....or maybe all 3 are happening at the same time.:?
Is it necessary to have manual switches to isolate the systems, or are they OK if both are connected to the battery at the same time?:h
If I have a solenoid that disconnects the vehicle power when when it isn't running, what happens if I start the vehicle when it is still plugged in to shore power?:h
Just trying to figure out how these 3 systems need to be isolated from each other to prevent letting the smoke out of something. It is REALLY hard to put the smoke back in.:)
  • Only thing I do is turn off the breaker for the converter if parked at home on shore power. Solar keeps the batteries up to full charge.When driving the regulators will do there jobs ,either solar or alternator.
  • RoyB's avatar
    RoyB
    Explorer II
    CHeck out MELLO MIKE's approach to using solar with his WOLF CREEK Truck Camper...
    Just search for MELLO MIKE WOLFCREEK on google...
    Roy Ken
  • Hi,
    All my charging sources play together well when I use the OEM converter.
    Be sure to get a temperature compensated charge controller for the solar.
  • I have all three connected all the time. They play together nicely. Whichever has the highest potential at any time bullies it way thru to do the charging. The other two stand aside to wait their turn at bat.
  • Can't answer them all but here's what I came up with this past summer experimenting with my new solar. Bogart Engineering SC-2030 solar controller connected to Bogart's Trimetric Battery Monitor.
    I get 10A to the batteries from the truck with the truck running, solar physically disconnected.
    I get 6A to the batteries from the solar with the truck off and disconnected.
    With both solar and the truck running I get 10A to the batteries.
    Same results with the converter vs solar, except a higher amperage out of the converter.
    Right or wrong I believe if the SC sees a high enough voltage level it does not provide an output thinking the batteries are charged.
    No need to switch one source off if another is hooked up. You could, and probably should, have enough disconnects or breakers to be able to isolate the solar for safety's sake. I can isolate the panel from the controller (fuse) and the controller from the batteries (disconnect switch).
    I have a relay that disconnects the truck batteries from the camper when off. I've started the truck with the camper on city power with no smoke.
