rastaman33609's avatar
Aug 20, 2014
TC Battery infomation over load
I have just spent the past 3 hours researching wiring info to charge the TC battery from alternator. I have already wired the truck a Dodge 3500
using #8 wire which some info suggest is 'good enough'. I only have 2 6 volt batteries. If I use 40 amp fuses that are rated for #8 wire I am wondering if they will blow because of higher amp draw by the TC batteries.
ALSO..my solenoid is wired to activate when the key is switched on...what is going to stop the starter from trying to draw from the TC battery to start and blow the fuses???
I am totally confused now. I know #8 wire is not as good as #2 however I have read in several posts that the difference is minimal.
Using #8 wire what fuses should I use at each end?
Will I need to wire the solenoid differently?
Thanks
