Kayteg1 wrote:
I think the site is a bit misleading.
To my understanding this picture shows the tank upside down, where the fitting up front is dump pipe.
You suppose to have toilet flange and vent pipe on the bottom side and I don't see it.
Do they offer compression fitting that you can put per your design?
BTW I had RV with 5 gallons black and that was just fine.
Yes that picture shows the bottom of the tank, with the drain up front. Based on the material i should be able to add compression style fittings for the vent and inlet.
Waiting to hear back from the manufacturer
