mkirsch
Feb 14, 2022Nomad II
As I recall Lance uses/used a very confusing way of measuring COG, measuring FORWARD from "the rear point of contact with the bed" or something to that effect.
Other campers measure COG from the front wall of the camper.
It sounds like Lance may have changed to this more conventional way of measuring. There would have to be an almost impossible shift of weight to account for such a large shift in COG otherwise.
As for fit, the odds of someone having a 2022 F350 and putting a pre-2013 Lance camper on it are slim to none, let alone someone on this forum. Does anyone even have a 2022 F350 yet?
The answer is, it probably will fit, though you might need to add a platform to raise the camper to clear bed rails and/or the cab.
