Grit_dog
Feb 15, 2022Trailblazer
mkirsch wrote:Lwiddis wrote:
There is no law against violating the tried and true rule..."Buy or select the camper first, then match an adequate truck to your camper." But do so at your peril.
I think the OP already did that. He's looking for a lance 835 or 850. The 850 being the heavier of the two, shows a "wet" weight of 2835lbs. Any 2022 F350 is going to be more than adequate ratings wise for such a camper plus a lot more.
https://www.lancecamper.com/truck-campers/850/specs/
No, you can’t say “any”, lol, or some try hard will come along and post up the special 9900 and 10000 lb F350 gvw packages and then argue the finer points of how if you’re not the engineer who designed it, how can you possibly say it’s safe when even the mfg says it’s overloaded!! LOL
