sonuvabug
Oct 03, 2018Explorer
Photomike wrote:
... snipped ... If you are only out in the shoulder season then you do not need a lot of heat to stop things from freezing. All you need to do is keep it a little above and a little heat will do that.
I tend to agree. Another solution is to simply burn a 60w incandescent light bulb in the basement area (assuming you have 120v hookup of course). The heat from a 60w bulb will keep everything in the basement from freezing. Farmers use this approach in their water well pump houses even with ground level pumps. You might also consider a teeny space heater. Both solutions assume you can position and support the appliances properly to avoid burning your TC down.
