towpro
Feb 18, 2015Explorer
The original question:
Do I wire camper load (and not camper changer) to load terminal? or leave them empty? I expect by using load terminals I can view current amperage usage the RV is using on a display. And If its a 20A controller, that that mean the current between battery and Load is limited to 20A?
If it is a controller with 2 separate battery connections (2 batteries) does it treat each battery different?
example, every 25 days it does a charge to knock sulfation off the plates, but a single 100w panel might not have enough current to run de-sulfation mode on 2 batteries at the same time.
44,068 PostsLatest Activity: Jun 05, 2026
