towpro
Feb 18, 2015Explorer
pianotuna wrote:
Hi towpro,
I tried to answer, but you did not understand.
your right. I did not know what "turn a light on" meant.
as I read the manuals it "sounds" like this "load terminal" is setup to help stop you from cycling your batteries down to far but cutting off the load at a pre set voltage on the batteries. in fact one said something about "if this light flashes, your current on load was over 2X capacity, reboot panel 4 times". (it really said reboot 4x)
I also see there is battery monitors like bogart TM-2030 that use a shunt to show current in ether direction.
I like stuff I can "LOOK AT" to show me its working. Sure solar is cool, but all it really is, is a battery charger and all the solar controller is going to show you is what the charging current is at this point of time (as well as probably voltage).
44,068 PostsLatest Activity: Jun 05, 2026
