AnEv942
Feb 18, 2015Nomad
towpro wrote:
...as I read the manuals it "sounds" like this "load terminal" is setup to help stop you from cycling your batteries down to far but cutting off the load at a pre set voltage on the batteries. ...
I use the 'load' terminal to power a separate 7.5 amp fused 12v circuit (during the day). It what I use for charging RC stuff. I used the load output due, as you read, it cuts off power (to load terminals) if batteries fall too low and Im not attending. Though the LVD is unadjustable 11.4v on ours- still its not flat-lining the batteries.. for me 12.2 is when I start turning stuff off.
44,070 PostsLatest Activity: Jan 14, 2013
