Another option would be Toyo 18s that have up to 4080 load rating with different higher rated wheels.
I didn’t have problems running 19.5s on my SRW, but it is expensive if you buy them new. They are rougher riding especially offorad. Some would say easier to go DRW, but if you want aggressive tires, you’d have to change the DRW tires as well.
I’ve run both Hankooks and Bridgestones and currently have Bridgestone 724s on the front. The Hankook DH01s seem to cup on the front but were more agressive. I run them siped. I like the Bridgestones slightly better and seem to wear a little better on the front but they aren’t quite as aggressive. The DH01s are no longe made.
You need at least 245s to fit those vision wheels correctly. One thing to note is the picture on the Bridgetone site doesn’t match the tread. A lot of people here have had good look with Michelins.
I’d search the archive or do Google searches to see the comparisons of each. Most of us run a set of 19.5s for a long time so we don’t have a lot to compare as we only have one set at a time.
