Kayteg1 wrote:
twodownzero wrote:
.... I would ignore anyone who says gvwr doesn't matter. It is all that matters.
I'd fully agree if you could find engineered GVWR.
All the numbers available to the owners are taxable numbers and have nothing to do with engineering.
That is why we are forced to talk about axle rating, not taxes.
Just because the manufacturers do not publish the methodology for their GVWR does not mean that it isn't based on engineering.
I find it amusing that people talk about the axle being rated for more without any data to support that contention. I recently read an article online that indicated that the AAM 11.5" axle in GM trucks has a .250" wall axle tube on SRW applications and a .500" wall thickness on DRW. My 40 year old truck has a 14 bolt 10.5" with .500" wall tubes; the newer trucks have 3.5" or 4" axle tubes depending. I don't think anyone would doubt that the new trucks are tougher than ever, but 40 years ago, a 3/4 ton truck had an ~8,600 lb. GVWR whereas today they are generally 10k and the 1 ton SRW GVWRs are also up 20+%, thanks to the newer 18" tires that have higher ratings.
Trucks don't have to just support the weight and stop it, but also handle their load in unpredictable and dynamic road conditions. Considering the load the newer trucks are capable of, I'm surprised that many newer trucks do not have rear anti-sway bars.
New pickups have bigger brakes and more power than ever, making it tempting to load them way beyond their ratings because the performance is SO much better than it was when I started driving and towing. I can't say I'm not tempted myself. But it's hard to predict all of the consequences of overloading a truck and the manufacturers are simply in the best position to do that.
19.5 tires are plenty durable and of course made for the weight we all want to carry but their tread designs are more focused on stability than traction and the stiff carcass does the same thing. They are heavier and harder on suspension components. Tires are the weakest link, so I understand the sentiment, but I've concluded that for me, if I get to the point that E rated tires will no longer support the load I'm carrying, I will switch to a DRW truck and use 6 of them instead of 4.
We all know that the parts are engineered with a safety factor. Some are comfortable eating into it; I am not. Weigh your load, be careful how you load your rig, and drive carefully! Your life or anyone else on the roadway could depend on it.
The simplest advice regarding hard side truck campers and 3/4 ton trucks is to just not do it. The same is true of most 30+ foot 5th wheels. These loads do not belong on 3/4 ton trucks. 3/4 ton trucks are ideal for ball hitch trailering, even with the largest of ball hitch trailers. They lack the payload necessary for bigger 5th wheels and all but the smallest truck campers.
The truck camper companies all lie about how much their campers weigh; my 815 was over 3,000 pounds when I loaded it up and took off for a week long trip in it. Then on the same trip I saw a slideout Lance on an F250. Care to guess how overloaded that was? I bet by close to 30% of his payload capacity. No jury is ever going to think that is safe.
