One of the worst things one can do to an automatic trans is have it flushed. Best thing to do is drop the pan, change the filter and fluid (using the OEM recommended fluid) and button it up. Also, drop the torque converter fluid, there will be a drain plug on the converter, you have to rotate the engine (bar it over) and align the plug with the removable inspection cover.
When you 'flush an auto trans, it looses the deposit in the valve body and can cause bad shifting and high temps if the orfices get plugged.
I never do that (flush), bad business.
Bet you have some floating gunk restricting an orfice.
