Grit_dog
Feb 19, 2019Trailblazer
Good garsh.... just another thing to worry about.
You can tell if your brakes are getting hot. And AFTER you pull over at the Crapper Barrel for lunch is not the right time.
Touching the bearing hub has always worked for trailer bearings for me. But then again, I’m not one to grab on tight to a hub that is obviously radiating heat. Put my hand on the stove once about 40 years ago. Cured me of that right quick.
