d3500ram
Jan 10, 2019Explorer III
If you are considering the "band-aid" philosophy," I might recommend that a bituthene type material be considered at the corners- Grace Ice & Water Shield or similar. This does not hold up long term if exposed to UV, but is self sealing and virtually waterproof when installed properly.
It might be another material to consider at the corners and edges but will need to be covered up with a exterior material.
44,066 PostsLatest Activity: Mar 14, 2015
