myredracer
Jun 23, 2019Explorer II
Lynnmor wrote:That's a good thought but I looked at that yesterday and the hole in the tube is way too small. I was thinking I could solder the #18 wires to the #12 and pull hard. Another method would be to run the new cable side to side above the coroplast. I'll have to see if that's do-able.myredracer wrote:
Not sure if I can get it above the coroplast.
Tie it to the old wiring and see if you can pull it thru. If it doesn't work, then go with the exterior plan.
Would rather not tie-wrap the cable across on the outside of the axles but should be okay. Will attach it at the rear of the axles so it's the least susceptible to damage.
