westend
Jun 24, 2019Explorer
What you've done is a series connection. You have both drums in series on one side and have two drums in series from one end of axle to the other.
A Star pattern typically has each drum having it's own pair of wires. The power can be distributed by a series wire connection to the source of power or, as I did, through a distribution block so that each brake assembly has its own pair of wires. I pulled it through heavy plastic flex-conduit and plastic boxes located against the frame. There are still two splices near the drums to power the magnets. I soldered mine and covered with heatshrink.
The 12 ga you used is definitely an improvement and you should notice better braking, immediately.
