myredracer's avatar
myredracer
Explorer II
Jun 21, 2019
Terrible factory splices in brake wiring
OMG, I never would have thought splices in the brake wiring could be this bad.
Am just replacing the backing plate assemblies on one axle. The first couple of splices I looked at were pretty bad so I cut all 8 of them out and this is what I found. The barrel connectors are marked "16-14". The incoming wires to each brake appears to be #18 ga. according to my wire strippers (I could verify on a gauge). Two wires should NOT be inserted into one end on these connectors.
I cannot believe this kind of cr@p workmanship can happen, especially on brake wiring which is obviously such a safety issue. Only two of the splices would be acceptable. I am soldering all 8 splices and using heat shrink tubing.
Only one crimp in the center of the barrel connector. Wire on right side not crimped plus note the wire is tarnished. The wire just slipped out of the connector and was only held in place by the plastic jacket on the connector.
Partial strands inserted into one end of the connector. The other end has two wires inserted into it.
Note on this one how the single wire was not fully crimped. Also two wires inserted into the other end and partial strands.
  • If you are the first owner of the trailer you're right this is poor workmanship. However, if this was a used trailer when you bought it, looking at the photos, my first reaction is these were done by a previous owner or shade tree mechanic.
    Due to liability issues it's hard for me to believe a trailer or axle manufacturer would allow such shoddy work.
  • Can't do better than a low resistance soldered connection. I've done the same on brand new trailers.
  • About the only time I use solder is if I need to join 2 small wires to a larger one. I twist the 2 together and solder, then use a right-size crimp connector to join that joint to the other. Before I put the wires in, I fill the connector with silicone. After I crimp, (Use good crimp tool, don't just mash it) wipe off the excess. Strong, insulated, and sealed.
