steve68steve wrote:
So, the stupid q: do I want the overloads to be engaged 100% of the time when the TC is loaded,
I would usually say yes, absolutely - overloads should be fully engaged when TC is loaded. IMO, how 'much engaged' would depend on desired right height and how much sway you get now when driving.
If ride height is OK, but you get too much sway, you might just want and inch or so taller pads in your case. If you also want the rear of the truck higher, taller pads. You could look at
Torklift stableloads pads for your truck, instead of making some.
