- fj12ryderExplorer IIIYeah, and my bicycle is quieter than either of them, and much lighter and easier to park. But it's not the right choice for many chores. And so the EV is not the right choice for many chores. Geeze, why is that so hard to get through your skulls?
I want to pull my trailer from Missouri to the Gulf. Now, do I use my noisy, stinky diesel, or do I use a uber-quiet EV? Oh, that's a tough one..well, maybe not. There is no EV from which to choose.
Probably someday there may be EV's that can pull a 5th wheel long distances without too many issues, but not now, and not here. At least 5-10 years. In the mean time there are uses for EV's. Still limited by infrastructure, but getting better. wilber1 wrote:
Yosemite Sam1 wrote:
time2roll wrote:
wilber1 wrote:
I understand range.
The simple fact is, a car getting 30 MPG can go farther on 70 lbs of gasoline than a Model S with a 1200lb battery. That is the hurdle that EV's face regardless of how superior electric motors are. Add a sustained heavy load situation like towing and the difference is even greater.
Turtle claimed better diesel torque and the Cybertruck was weak.
I want to know why the diesel with all that power and torque is so slow at accelerating (loaded or not) compared to Cybertruck.
And pissed off neighbors with the noise and stink.:B
Newer diesels are pretty quiet and they don't stink.
I'm actually a fan of EV's for many applications, I'm just not willfully blind to their limitations.
Nope. They all stink (gas or diesel) and they are all noisy. It’s just people get used to it. Drive electric for two weeks and then try and go back. That’s why so many households that switch to an EV end up changing out the rest of the vehicles within a couple years. Your garage starts to smell like any other part of your house. :).
Oh. And on edit. They are also all gutless...unless they are REALLY LOUD AND STINKY... and then they are still slower. :).- Yosemite_Sam1Explorer
I better tell my neighbor that so I don't have to wake up as early as him for his shift.
And that the gas crisis won't be happening again so he need not stock up diesel anymore.
Before I start to think of buying a Deere tractor to get even.:B - 8_1_VanExplorer
Wow, I almost asked Elon to refund my hard-earned $100 for the Cybertruck with all the ghosts found under the hood of this truck.
Until wait, problem with 30 to 50% power drain on Cybertruck. My ICE is worst at more than 50% reduced mpg when towing.
I can only go 200 miles in full charge when towing. Wait, that my regular stops for gas up and lunch on my camping trips.
I'll have problems with off roading? How, it will have a ton more torque and ground clearance?
The bullet proof glass shattered? Who cares, I'm not going to Texas anyways.
The looks, oh yeah, it still have not grown into me yet. Anyone, wants to buy for $5,000 my high-priority place in order-reservation queue?
Real world towing is showing a range of 30-50 percent verses unloaded. The reduction is 50-70 percent.
BTW: My diesel has a 30 percent reduction when under load verses unloded.
Huh?:h:)
When and where? Have they already tested the Cybertruck under towing conditions? Dang, I missed that one!
Here is your Tesla towing. Watch what happens. The look on the kids face is priceless! LOL
Tesla towing - wilber1Explorer
time2roll wrote:
wilber1 wrote:
I understand range.
I'm actually a fan of EV's for many applications, I'm just not willfully blind to their limitations. - wilber1Explorer
Reisender wrote:
Then why is your truck so much slower?
Let me try to explain to the fan bois.... my 12 YO truck will put out 7x's the amount of torque the Cyber junk will put out.
How do you know it is? Until it is certified at the track nothing is true. Nothing.
But lets say the spec's on the cyber junk are all true and the cyber junk goes 0 to 60 in 2 seconds or whatever. The reason the cyber junk would beat my truck is because HP and not torque. HP determines how "fast" AND "quick" a vehicle is.
Must we really go over this AGAIN? Torque is not power. I can have 1000 ft/lbs of torque at 1000 RPM and have less than 200 HP.
It takes a lot of HP to go fast and quick and you know what that takes? Yep, a lot of energy.
My car uses about 1.2 gallons of gasoline to drive a little less than a mile. A gallon of gasoline has a LOT of energy in it unlike LI batteries.
In fact a LI battery has about 10% the energy content of gasoline pound for pound. That means if I towed the trailer I have with an electric truck I would get about 40 miles down the road before I would need to "fill up" again.
Or to look at it another way I would have a 3.5 gallon tank in my Duramax. Nice hu? LOL :B
This is why lying Elon if FOS when he talks about the range of his cyber junk with a 125KW/hr battery.
Even a little tiny car made of all aluminum, with every aero trick in the book it can only go a little over 300 miles with a 100 KW/hr battery. And lying Elon said his jacked up junk made out of plate stainless like a armored truck with wide tires can go that and then some. He's full of bovine excrement.
Ford said they will bring it to lying Elon. But Ford will have apples to apples and not a 4x vs 2x like lying Elon did.
Good luck Elon. LOL BTW better get that FSD car done like you said would be finished by the end of this year! :B
I'm waiting for a longer kilometric answer for this simple burn!:C:B
In not sure why it’s a hurdle. I don’t really care how much my fuel weighs. I don’t think I have ever met anyone who does. EV’s outperform liquid fuelled vehicles in every way. Plus they can be fueled at home or work. I don’t think you are going to convince the next generation of car buyers that an old fashioned stinky noisy gutless vehicle that has to go to a gas dispensary to be fueled is better than a an EV because the fuel source is lighter or denser or any other goofy properties.
Just sayin. If you grow up in an EV household no way you look at something that “burns fuel”.
The problem is, batteries just can't carry enough "fuel". A Model X towing a 4400 lb horse trailer had a range of about 120 miles at highway speed. I can go close to 300 towing a 12K fifth wheel on 250 Lbs of diesel and refuel in 15 minutes. I could double that simply by adding aux tank and adding another 250 lbs of fuel. The Model X would need to add another 1200 lb battery and it still couldn't go as far as my truck with the stock tank. That is what EV's are up against as tow vehicles. - Yosemite_Sam1Explorer
And where else can you find where fuel is delivered to you -- and very cheap at that. wilber1 wrote:
Just sayin. If you grow up in an EV household no way you look at something that “burns fuel”.- Yosemite_Sam1Explorer
time2roll wrote:
wilber1 wrote:
I understand range.
And pissed off neighbors with the noise and stink.:B wilber1 wrote:
I understand range.
44,056 PostsLatest Activity: May 04, 2014
