Timmo_
Apr 20, 2021Explorer II
Random thoughts about battling lithium-ion battery fires---
* The recent Tesla accident near Houston, firefighters used at least 32,000 gallons of water to extinguish the flames. Firefighters at the scene contacted Tesla for advice on how to extinguish the blaze and were told just to let it burn out.
* 32,000 gallons of water weighs over 132 tons.
* Average fire truck holds only 500 gallons of water.
* Tesla's Emergency Response Guides excerpts--
FIREFIGHTING
USE WATER TO FIGHT A HIGH VOLTAGE BATTERY FIRE. If the battery catches fire, is exposed to high heat, or is generating heat or gases, use large amounts of water to cool the battery. It can take approximately 3,000 gallons (11,356 liters) of water, applied directly to the battery, to fully extinguish and cool down a battery fire always establish or request an additional water supply. If water is not immediately available, use dry chemicals, CO2, foam, or another typical fire-extinguishing agent to fight the fire until water is available.
Battery fires can take up to 24 hours to extinguish. Consider allowing the battery to burn while protecting exposures.
Houston, think we may have a problem.....
FIREFIGHTING
