ShinerBock wrote:
Yosemite Sam1 wrote:
May I recommend that you should just stick to what you know? lol
My neighbor's, and hunting buddy, daughter worked there. She lost her job as plant-supply chain manager but get a higher paying new gig with Amazon.
LOL, I would say the same to you about your passed assumptions about the medium/heavy duty industry, "poverty level" salaries in other states, and how electric utilities work in other states.
What does Amazon or your hunting buddy have to do with the list of mainly office positions that left have to anything?
And what are you talking about "higher population density" is causing pollution? In California? Where if you want to develop tracks of land, usually bare desert, for housing, you have to plant trees along roadways and pathways, reserve a good portion of it complex for green area and semi-forested parks and currently, new homes are with built-in solar paneled roofs, otherwise it would not sell?
Higher population density causes greater pollution in a given area especially things such as NOx which stagnates in the troposphere where it is bad pollution. This is why southern California's air pollution is so bad and needs to be heavily regulated. This is not the case in most other areas of the US due to its much lower population densities. Emissions such as NOx, which has a very short lifespan due to its reactivity, has a chance to dissipate into the stratosphere(where it is a good thing) so the same regulations are not needed.
Decreasing the population density(moving away from metro areas) would be a lot better for local air pollution than many of these regulations or even lower emissions vehicles.
Another adage that you might want to get wisdom from: If you find yourself in a hole, stop digging.
1. Direct knowledge, where his daughter actually presided over the plant's decommissioning is better than your crystal balling.
2. Air quality actually improve in urban green zones -- even if surrounded by residential area.
