mkirsch wrote:
Reisender wrote:
Yah. I agreed with everything you just said. But for pre-heating the Tesla doesn’t work like that. The poster mentioned he had been running the genny for 24 hours. It takes 5 or 7 minutes to pre-heat the tesla and it can do it from it’s own battery. He or she was running the genny for other reasons. Probably low charge. Makes sense, albeit really slow. Even at 24 amps 120 volts from that genny.
Maybe you missed the part about "severely reduced capacity in cold temperatures?"
Sure you can warm it up using its own batteries, but how much of a hit on range will there be pulling from the cold batteries?
Maybe the owner ran the generator to keep the car and batteries warm for the 24 hours it sat there, rather than let the batteries get cold and having to start from scratch? That generator can't run for 24 hours at full capacity, and isn't all that quiet so I doubt it was actually charging the car. Those Hondas are really only quiet at idle.
To go from minus 20 to plus twenty in our driveway while not plugged in takes 5 or 7 minutes. It’s about a 2 percent hit on the battery. I’m not sure what severely reduced capacity means but typically around here one should count on losing about a third of your normal range for the winter temps we get.
Teslas don’t have anything like a block heater function. Just plugging it in won’t keep anything warm. The cars needs to be actively charging for heat to be diverted for battery warming.
Again. Not questioning the drivers motives for plugging in. More than likely he had a good reason. But pre-heating wouldn’t be one of them unless he wanted to keep the interior of the vehicle warm continuously for days on end. Maybe a pet inside. Who knows.
Agreed on the noise of the genny. We have a 3400 watt propane genny that we use for emergency home backup. Once every couple months we exercise it and use the Tesla as a variable load as I can vary it from 5 to 24 amps on 120 volts. Works well. But when up at 24 amps it’s working hard and is considerably louder. Meh. It’s once every couple months for 20 minutes and the neighbour does the same thing so it’s all good.
Pre-conditioning on navigation to a supercharger is another topic. In this case the battery is preheated about 30 minutes or so before arriving at a supercharger. This insures max charge rate when arriving at the supercharger. But that’s all automatic and outside the scope of this conversation.
Cheers.
