IdaD
May 13, 2017Explorer
spoon059 wrote:alexleblanc wrote:
This year the SRW trucks have different rear axles between the F250 and F350 so my understanding is that it's no longer just a sticker rating deal and the F350 SRW has an actual beefier axle rated for 7200lbs ~ instead of 6200lbs ~.
Are the axles actually different though? The Ram axles are the exact same between 2500 and 3500, but can be rated between 1000 lbs to 500 lbs different, depending on wheel combo. I don't know enough about the new Fords (way too expensive for me to even research!!!) to know if there is an actual difference.
I think the diesel 350 gets a different axle than the gas 350 or any 250 on the new Ford. The diesel 350 axle might be the size of the AAM in the GM/Ram HD trucks. I believe the Ford previously was always a bit smaller.
