jerem0621's avatar
jerem0621
Explorer II
Jun 22, 2019
Test Drove a 6.2l Yukon Denali
Just like the title said, I just test drove an older 2007 (or 2010). Yukon Denali XL AWD with the 420 HP 6.2l all aluminum V8. I am considering purchasing this vehicle but have not yet.
This vehicle had high miles (200k) but was absolutely immaculate and seemed to be well maintained.
The coolant looked great, there was no apparent blow by on the engine. The transmission shifted great and it drove just like a new one (as far as ride is concerned)
The price was great and the interior was way above average for a vehicle this old.
The only problem was two fold.
1) there seems to be a .5-1 second delay when I depress the gas after I let off the accelerator. Spirited driving was a challenge. After all, this was a test drive.
2) When the engine would go it left me kind of surprised. This does not feel like 420 HP. This feels more like 285 HP. My FIL has a 2007 Navigator with the 5.4 that only had 300ish HP and it was much much quicker.
All that to say, does this sound like a normal 6.2L from GM with 3.42 axle ratio? Could the AWD be stealing power?
There are zero leaks, the frame is clean, the suspension looks and feels great. Just these two nags.
Thanks!
Jeremiah
  • I'd get an oil analysis done, before buying a 6.2L with that many miles. Keep in mind it's a light-duty motor with a light-duty design life (150,000). It's designed for power over longevity, and feeling sluggish could be low compression .
    The lag is probably just the electronic throttle body. The earlier GM ones were slow to move, relative to a mechanical throttle body, and combined with somewhat invasive torque-management, can make it feel how you describe. And a high-mile one might need a good cleaning.
    The AWD in that rig won't "steal" power, since it's still a mechanical coupling (clutch based engagement), and the clutches won't engage anyways unless it detects an difference between output shaft speeds.
  • I have an 11 Yukon Denali. Pretty similar to what you are talking about.
    While I don't feel like the rig is under powered, I don't think it feels like 400 + HP.
    My complaints on mine is it runs hotter than I think it should as a tow vehicle (swapping to a bigger tranny cooler next week). It has more rattles than any vehicle that I have owned (other than a 2500 Burb I bought with 120k on the clock). Interior does not compare to the top trim levels of similar year Ford or RAM. And I have had ongoing issues with the Stabilitrack - have had wheel sensors go out twice where it shuts the stability control off, and am experiencing similar problems again.
    When I was looking for this vehicle 3 - 4 years ago, I found TONS of Burbs/Yukons for sale with 200,000 plus miles. So they do seem to stay on the road forever - and they hold their value well.
  • I have a 6.2 in a Silverado. On the ruck boards they report GM ‘detuning’ HP and torque off the line to save the tranny. So far I love the engine, like the 5.3 need to let it sing to get max power . . . But it sounds great when singling!
