Bheffington's avatar
Bheffington
Thanks to forum......
I bought the jack antenna and the oxygenate shower head. Best $75 ever spent on the trailer! I went from a drizzle in the shower to a nice and pleasant shower. I had maybe 40% signal strength and it went up to 95%, 4 channels to 12. Thanks for the recommendations!
  • This forum has helped me in too many ways to count over the years, ever since my days with the PU.
  • Just installed my JACK.
    It does pay to read the installation instructions more than once. I had pins in wrong holes.
  • I replaced my crank up batwing with the Jack Antenna and got 3 times the stations as before.
    It is an easy install. just pull 2 pins and unhook the coax, then replace, The Jack still uses the box in the wall with the green light, You don't need the outside power supply that is provided in the kit, the instructions on that are clear and easy to follow, Here is an ad for them with a good video that helps.
    Jack Antenna
    Good Luck I really like mine,
  • I`ll have to look into that! doses that also replace the amplifier in the wall? the one with the switch and green light. I get no stations at home. I used to get a lot, now I barely get 2 major stations! and camping I get none.
