Cummins12V98
Jan 21, 2021Explorer III
RoyJ wrote:Cummins12V98 wrote:
If he had that weight there would be little space from top tire to bottom fender opening UNLESS he was bagged.
I also think you may be high on the tire capacity. Did you figure single or dual ?
My bad, forgot to use dual numbers. Should be 11,640 lbs @ 80psi.
Thanks. I still have nearly 2k in tire capacity over my RAWR.
