NRALIFR
Jan 21, 2021Explorer
Rich1961 wrote:RoyJ wrote:NRALIFR wrote:
I’m not sure what axle was on the rear of the 2011-2014 F450’s, but it wasn’t the Dana S130. None of the F450 pickups used that axle, it was used on the cab and chassis F450’s though. The 2008-2010, and the 2015-2016 F450 pickups used the Dana S110 and 19.5 tires and wheels.
At the beginning of the video, you can clearly see that the front driver side wheel is 8-lug.
The ‘11-‘14’s were oddballs that weren’t much different from the F350.
According to this guy his 2015 pickup came with an S130, which in the photos look identical to his F550:
https://www.ford-trucks.com/forums/1410665-f450-rear-axle.html#post15860273
Was there a change / heavy spec pkg that used the S130?
2011 thru 2014 used the Dana 80 in the F450 pickup.
That’s what I was thinking, but couldn’t find any info verifying that. I believe the 2011-2014 DRW F350’s used the Dana 80 as well.
According to the info in the FTE topic RoyJ linked, the rear axle in my 2016 is an S130, not the S110 like I thought. Mine never had the paper tag that clearly stated the axle type, and the metal tag on it isn’t at all clear about what it is.
But, this casting stamp supposedly identifies it as an S130., and that’s exactly what mine looks like.
So, maybe it is.
