valhalla360 wrote:
You are quoting a different type of "overweight" laws. There are no specific safety laws. An LEO could sight you for what he considers an unsafe load. This is reported to happen in BC Canada. We do not hear much in similars report in the US except in Southern California coming out of Glamis sand dunes. Not sure what the citations are based on there.
The laws referred to in these quotes generally have little or nothing to do with is the truck safe. These are weight laws that relate to if your truck will do excessive damage to the pavement. If your RV weighs enough to run afoul of these laws, you are so grossly overweight its silly. Generally, the big commercial trucks are fully capable of handling weights well in excess of the legal limits.
The discussions on this forum are generally about if your non-commercial rig is capable of handling the weight safely. You are unlikely to get a ticket unless you are grossly overweight and there is an accident. Even then, for the simple fact that most RV's disintegrate in a serious accident, it's hard to prove what your weight was.
That doesn't mean it's a good idea to exceed the manufacturers weight rating. If you kill someone because you excess weight didn't allow you to stop in time...you are still at fault even if the cops don't write you a ticket. The manufacturer gave you the approved weights. Unless you have the engineering background to fully understand how they set the limits, you will be hard pressed to justify exceeding them.
Safety is the responsibility of the operator and NTSB makes recommendations to assist operators.
NTSB Home
https://www.ntsb.gov/
NTSB - An Independent Federal Agency Charged with determining the probable cause of transportation accidents and promoting transportation safety, and assisting victims of transportation accidents and their families.
I safely operated a 2001.5 RAM well over it's manufacturer low 8800 lb GVWR for years. That truck with the camper option was configured similar to a 3500 SRW which was not offered that year, and was licensed to 12K GVW with my state.
For many years the difference between a 250/2500 and 350/3500 was very minor. Now RAM and Ford have actually engineered the two differently. RAM with a completely different rear suspension, options for the heavier duty transmission and higher output engine reserved for the 3500, and FORD with actual differ running gear components.
The 250/2500 towing issues continue to come up because dealers push 250/2500's with a higher flooring order bases. Walk any dealer lot and see for yourself that the majority of the SRW trucks are 250/2500's.
I have said it in the pass and will say it again, if buying a new TV for a 5th wheel, the starting point should be a 350/3500 SRW, or you will end up like I did. I bought a 2500 when I was towing a 26' 5th wheel, and within a few years I had a 29' much heavier trailer, and then began snowbirding with it. Which meant that is was load to its max.
That is another point. ALWAYS plan your weight on the trailer's maximum weight, not some reduced amount between dry weight and full GWVR of the trailer. Pin weight on most 5th wheels is effected quite a bit by holding tank levels and fresh water on board. Many trailers have the fresh water tank in the rear, moving the water forward to the waste tanks can effect the pin weight by hundreds of pounds. Running with a empty rear fresh water tank vs and full one will create more pin weight.
Another observation is that for the last ten years I have seen the same large trailers arrive each year at our snowbird park behind the same 250/2500 TVs. They did not fall apart of the road or get sideline by a LEO weight cop.
Example of a newer setup, a Landmark 365 with a 2500 Chevy TV, why??? Did the salesman say the 2500 can tow anything, did the owner already have the TV, did he just not know about weights. This has only marginally improved in recent years, however on the Heartland forum their are more and more people upgrading their TV shortly after purchasing a larger trailer.
I have in past years see lots of trailers arrive with damage from a china bomb tire failure. This is improving with more manufactures supplying LRG all steel ply OEM tires and people upgrading from LRE ST tires to LRG all steel ply tires, making trailers safer to tow. Friend blow a china bomb on I-10 between Palm Springs and Phoenix, he said the rig went from the right lane to the left land and almost onto the median before he regained control of the rig.
For all the 5th wheels on the highway, and we see a lot of them in the Phoenix area, they have a pretty good safety record regardless of the TV up front.
