Wishin
Jan 25, 2018Explorer
I think the opening poster will be fine with the new trailer. I checked the spec.'s of that model at a dealer and the dry tongue weight is pretty light. Just make sure you end up at the % of weight you expect and not too low. As you likely know, too low and it may not be as stable.
Good luck, if I were you, I'd get the trailer you prefer since you expect to be within the numbers of your truck based on actual weights and estimates, not just guessing.
44,070 PostsLatest Activity: Jul 26, 2026
