AmericaOverland wrote:
gmw photos wrote:
Each tire is rated for 1750 pounds at the stated inflation pressure on the sidewall.
It does not answer the question as to whether these tires are really way under-rated for this trailer, or if I have the capability of going to 3500 lbs (most I would go is about 3000 lbs gross weight).
And why is the ST tire not a quality one? What is the difference between an ST and an LT tire?
The tires you chose, and for the reasons you chose them, would not have been the way I would have gone. But, you have already got them, so I simply answered the question about the weight capacity of the tires.
Remember too that if your trailer weighs 3000 pounds in total, some of that weight is tongue weight. Let's hypothetically say it's 400 pounds. That means the tires are carrying the remaining 2600 pounds, or approximately 1300 each tire. Assuming the trailer weighs the same left to right, which it may not.
