bigcitypopo wrote:
Huntindog wrote:
IF, and only IF you must stay with a ST tire, Maxxis appars to have the best reputation.
There is however a huge drawback to them. Availability.
This forum is full of threads from those that had to WAIT for them as they had to be ORDERED.
In my mind this is a potential problem. Any tire can suffer damage on the road, and need to be replaced. Even the good ones. Yes the odds are a lot better, but should you need a replacement Maxxis while on the road.... Odds are you will not be able to get one.. You will either have to wait several days, or accept a inferior replacement.
So if you are able, I recommend going with LT tires. They suffer much less from the quality/reliability problems that plague the ST tires as a whole. They do not have the 65 MPH speed limit restriction, and are widely available just about anywhere.
Even if a LT tire should need replacing on the road, and the tire shop doesn't happen to have your brand in stock....They will have a LT tire of another brand that will be perfectly serviceable, so that you can continue on your trip without a tire concern.
Balancing and metal/rubber stems are down on the list as far I'm concerned. Balancing will likely never pay off in tire wear on a TT, and a solid axle won't transmit vibration to the TT like a steering/independent one on a car would. So long as the stems are rated for the PSI, then they are fine. Metal ones will last practically forever, but usually cost more..
Great info.. My tires are 225/75/15... I am game for an LT tire... Recommendations?
Sure. I'd ditch the 15s and get some 16s. After too many ST tire failures to count, that's what I did about 7 years ago. Not a single issue since I made the upgrade. And I gave the ST tires every chance.
I USED to be a ST proponent, believing all the propaganda that is posted on the net....That stuff all originates from those that SELL tires. I wish I could have all that money back that I wasted upgrading from one ST tire to the next, and one load range to the next. Finally ending up two sizes and two load ratings above the stock tires, which required new rims... And those were LRE ST tires.
Lasted less than a year before a catastrophic blowout. Laying floor mats to keep from burning myself on the hot AZ pavement while my wife was trying to signal the trucks to change lanes so the TT wouldn't rock so bad as they blew by... It was past time to throw in the towel
Don't do as I did. Make the jump now and save yourself a lot of trouble and money.
And for those that are thinking that the tires were run low... Absolutly not. I have a 80 gallon 2 stage compressor in my garage. My air hose can reach the TT in the drive. It doesn't move until the tires are aired to spec.
