transamz9
Jun 17, 2013Explorer
OP, they must be charging you 4 hrs labor @ $100 per hour to do a 2 hr job. The part is only $40. I think I would take it to a different place. GM also has specs that allow a little play up and down. Dodge is the same way with their ball joints. They will have a little play up and down right out of the box. It's the way the parts are designed to be.
You may have other problems that they are just masking. If you are having tire wear problems or something like that, the GM 4X4's are known for bearing assembly's getting dry and loose.
44,056 PostsLatest Activity: Nov 19, 2013
