3_0charlie
Feb 28, 2014Explorer
This summer will be #3 for my Kodiak 263. No warranty work done, nothing loose, no leaks. I did three 'repairs' since I did not like the design and manufacturing: 1. the external electrical box, right behind the A-Frame. Unprotected galvanized steel is not the proper material, and upon replacing it with an external weatherproof box I found a loose marette - on the main 12V line. 2. The shower pan was not structurally supported around the drain. I built a wood support around the p-trap. 3. The same shower pan and walls were not sealed at their base. Quick bath silicon treatment took care of that.
Other than that, all other equipments are working as intended (AC, electrical, slide-out, plumbing).
